Ocean rendering with Dome Camera
  • Ocean rendering with Dome Camera
    Hello,
    I have just stumbled upon the limitation, that the ocean render mode only works with "normal" cameras, not with the Dome Camera or a Spherical setting in the render setup. I suppose that when I put in a Dome Camera, let it point straight up and give it e.g. 220°, the ocean optimisation clips away the ocean completely since it is nowhere inside a camera FOV. Could this be changed, so I could render a complete ocean within a dome view?
    Thanks,
    Bob
    yes, the ocean is built using the camera parameters only inside the camera frustum, that's why it does not work with dome camera. i will see what can we do about this
    ______________________________________________
    VRScans developer
      Cool, thanks for having a look, and for the quick answer.
