Standard Source Emitters
  • Standard Source Emitters
    Has there been any chats about adding a simple source emitter that has directional options like Fume FX?
    Cheers
    Tom
    That would be interesting indeed. For now you can use discharge modifiers in Surface Force mode to direct the flow in a certain direction.
    Cheers!
      Just to add to the emitter wishlist which you probably already have .. variable viscosity would be cool.
      In Naiad you could also set the density of the water per emitter which was really cool as you could have different sources float on top of the others. It sounds like a lot of work to implement but would be awesome!
      Basically a per source options for the dynamics of the fluid
      Adam Trowers
        Yup, we've had this in the list for a long while, I hope we can get there soon
