VFB and denoiser improvements
This is a sticky topic.
  • VFB and denoiser improvements
    VFB panorama Viewer
    Integrated viewer for your spherical panoramas. In the VFB menu View / Panorama View
    Proportion Guides Layer to help with scene composition in VFB
    A new layer type in the VFB providing user customizable overlay lines for easier image compositions. Create layer / Composition Guides
    Add albedo RE for AI denoising
    New private RE to improve denoising quality. Helps preserving more details in the image, especially in metallic/reflective shaders.
    Batch image processing in VFB2; Option to process exr files
    The next logical step for the BIP tool. Needs polishing for sure.
    Flip button in the VFB
    Shortcuts (M) and (Shift+M).
    Peter Matanov
    Chaos
    I misread this and though it could output EXR files from VRIMG files. I was frantically looking for this option. So this would be a nice addition to save to different formats as well.
    A.
    www.digitaltwins.be
      Yes, it could be nice if it could batch process VRIMG files too.
      AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
      2D | 3D | web | video
      jiri.matys@gmail.com
      https://gumroad.com/jirimatys
      https://www.artstation.com/jiri_matys
      https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
      https://www.instagram.com/jiri.matys_cgi/
      https://www.behance.net/Jiri_Matys
      https://cz.linkedin.com/in/jiří-matys-195a41a0
        Haven't checked yet but could the panorama viewer work with sequences? We are rendering a lot of latlong animations at the moment.
        Maxscript made easy....
        davewortley.wordpress.com
        Follow me here:
        facebook.com/MaxMadeEasy
        If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
          We only show the current image in the VFB as a spherical image; the VFB can’t play animations. The Cloud preview tool here can do that:
          https://docs.chaos.com/display/VCLOU...onePreviewTool
          but I think it requires a video file (i.e. it won’t work with just a sequence of images). It is on the “to do” list for Chaos Player to add playback of spherical sequences, but it’s not implememted yet.
            Does it prioritize rendering the buckets in the current view angle of the panorama?
            Follow me here:
              Looks like no... Could also do a new bucket ordering method where it concentrates on the horizon line to top third to bottom third first then does top and bottom.
              and whilst I think of it, does VRay do anything clever with doing less samples in the polar zones so when wrapped you don't end up with effectively over-sampled areas from the distortion of the image?
              Follow me here:
                Yes, it seems like a good idea to focus on what's visible; will think about it.
                No, not right now.
                  We've been running a LOT of lat-long high resolution animations, I hate to think how much over-sampling has been happening across the polar regions which could have been quicker!
                  Follow me here:
                    Also, if you switch into the panorama viewer and you haven't rendered from a spherical view maybe it should prompt? Or in the render settings maybe it should be more obvious which mode to switch to?
                    If I set to Spherical Panorama it's hov 45 and vov is 400 for some reason.... could be a nicer user experience.
                    Follow me here:
                      All good points - will think about them.
                      Best regrads,
                        This would be a tremendous help for us as well .
                          Does this work with all denoising engines (Nvidia, Intel and the Vray one)?
                          Aleksandar Mitov
                          www.renarvisuals.com
                          office@renarvisuals.com
                          AMD Ryzen 9 9950X 16-core
                          96GB DDR5
                            It's for the AI denoisers (Nvidia/Intel). The V-Ray one already has the necessary info.
                            Peter Matanov
                            Chaos
                            • #15
                              I was hoping we would be able to batch process an animation with Optix new temporal denoising mode. This would be super handy.
                              Right now there is no other way to denoise animations flickerfree other than Vray denoiser standalone tool right?
