I am unable to properly render more than 2 VrayBumpMtl materials chained together with the GPU engine. If more than 2 VrayBumpMtl materials are chained together, Vray GPU seems to render only the last one in the chain. The help docs don't seem to mention any such limitation. Is this a bug? CPU engine renders it fine. Please see the video attached.
Can't render more than 2 VrayBumpMtl materials chained together with GPU
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
Sure, see attached.Aleksandar Mitov
96GB DDR5
Thank you! Is there any other method of stacking multiple bump maps with GPU that I can use as a workaround in the meantime?Aleksandar Mitov
96GB DDR5
Blend the maps, and use one bumpMtl.
You may have to do some minor math as to how much a map ought to blend in, so to replicate the bump amount for each.Lele
emanuele.lecchi@chaos.com
Disclaimer:
- Likes 1
I see. Thank you both!Aleksandar Mitov
96GB DDR5
- Likes 1
