Vray6 beta crashes after opening the material editor
  • Vray6 beta crashes after opening the material editor
    Sorry for my first post in this forum, I installed Vray6 and when I can't wait to start using it.
    It always crashes when I open the material editor and start previewing the material sphere.
    Can anyone help me, thanks!
    Welcome, and there's nothing to be sorry about!
    Do you mean it crashes when you doubleclick on a material editor preview sphere to make it bigger?
    Or as the material editor starts?
    Which material editor: slate or the compact one?
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Hey wong_wei and welcome to the forums,
      What driver are you using? and what version of 3Ds Max?
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
        Lele, thanks for your reply.
        I'm using slate material editor and it crashes after a while after I open the material editor.
        I tried to delete the 3DSMax user profile, it does not work.
          Hello,
          Do you have third party plugins like ForestPack and RailClone ? They are not compatible with the new V-Ray 6 Beta yet so they will crash.
          Yavor
          Yavor Rubenov
          V-Ray for 3ds Max developer
            This is my system information.The driver version is Nvidia RTX4000 Production Branch/Studio : R515 U1 (516.25)
              Do you have some 3rd party plugin installed? Like Forest Pack? Most of those are not compatible with V-Ray 6 and need an update from the respective vendors.
              Peter Matanov
              Chaos
                Originally posted by yavor.rubenov View Post
                Hello,
                Yavor
                Hi,Yavor. Plugin only installed Tyflow V0.16135, I tried to remove it, but it didn't work.
                  Just in case, download the recent recommended driver 512.59
                  Make sure to check custom install, then check clean install option
                  then restart the machine if it doesnt automatically
                  Muhammed Hamed
                  chaos.com
                    Ops sorry, saw the dump
                    Yavor Rubenov
                      I'm gonna take a stab in the dark and guess it's this problem: C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\UPI20XXBase\UPI\upiconfi g.xml
                      Meaning the 20XX whichever version you're using is missing, having the same problem as the OP, apparently that folder is missing which might be the culprit. If that's the case it's an Autodesk issue. I could be wrong however.
                        So we checked the dump file and found the reason for the crash. It's always a good idea to clear previous crack files before installing a legal copy of V-Ray.
                        Peter Matanov
                        Chaos
                          Thanks, I don't know how to clean the crack file, does it have a path?
                            3ds max 2019 last service pack also crashing when open material editor (simple one) that advanced (slate) doesnt crash
                            • #15
                              Am I reading this correctly? So you installed pirated software and are now asking the company you essentially stole from to help you clean up your mistakes?
