Surface faceting when using SSS with GPU
  • Surface faceting when using SSS with GPU
    I get faceted surfaces when using the SSS feature in VrayMtl with the GPU renderer. Is this a known issue? The CPU engine doesn't exhibit this behavior.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    It will be fixed once the new SSS mode is implemented for V-Ray GPU. You'll get the same thing on CPU with the old "Directional" mode.
    Peter Matanov
    Chaos
      I see. Thanks!
      Aleksandar Mitov
      96GB DDR5
        You can try subdividing the meshes.
        Peter Matanov
        Chaos
