Hi, testing the new sss, and when I use an opacity map it's messed up it render's black ... plus, can we have an option into the vray material that when we use opacity we can still see the reflection ? because for characters let's see, I need this for the lacrymal gland transition for exemple ,if the reflection disapears as the opacity fade, I loose the details of the reflection in the transition part. so would be nice if you guy's ca add a checkbox let's say called : work with opacity in the reflection rollout or something like that so that if we need the reflection to not be affected by the opacity map, we have an option for it. I just made a few test so far, but what seems better compared to the older directionnal sss in the vray mtl is that there is less shadow shifting and a bit less greenish darkening happening. we still have at angle the darkening happening though, wich is not good.
Vray mtl sss don't support opacity map ...
