VRayEnmesh Mod resets Cropbox when max scene is loaded if UVW Unwrap mod is in the source
  • VRayEnmesh Mod resets Cropbox when max scene is loaded if UVW Unwrap mod is in the source
    With VRayEnmeshMod, if the UVW Unwrap modifier is added to the source object, the Crop box size will be reset to the max scene load.
    Confirmed with Bata2
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    HI I can not reproduce the issue but am not sure if I understand correctly what you are doing. I tried this:
    My V-Ray version is:
    Vladimir Krastev | chaos.com
      I wanted to point out that I tested also with the UnwrapUVW modifier below the Enmesh modifier with the same result.
        The source of the instance [Notated as OBjects on the UI]. (Not the base)
        Screen capture
        https://drive.google.com/file/d/1j66...MRel5adG6/view
        oakcorp.net
        v-ray.jp
          Hi you are correct. If we add a UnwrapUVW modifier to the instanced object the crop box size keeps resetting to default every time we reopen the scene.
          Let me do a bit more testing and I will get back to you.
            I have logged this issue for developer review under VMAX-12402 in our bug tracking system..
