Before you post
This is a sticky topic.
  • Before you post
    Welcome to the V-Ray Application SDK section of the forum!
    The V-Ray AppSDK is a high level API wrapper for most of V-Ray's functionality. It's aimed at integrators, be it for web projects, full DCC integration, pipeline tools etc. What you can't do with it is write custom render plugins, such as shaders (you can still use shading languages like OSL).
    We support four languages currently: C++, C#, Javascript (Node), Python.
    If you want to obtain the SDK, contact us through this form: https://www.chaosgroup.com/vray/application-sdk#contact
    A few simple requests before you post:
    * First check the documentation and examples for information that may answer your question or problem.
    * Search this forum for similar threads before posting new ones.
    * Please state the programming language you're using when posting new threads.
    * When posting in the Problems section give details about your development environment, such as OS version, GPU driver, compiler and so on.
    -- Nikola Goranov, AppSDK dev team
    Nikola Goranov
    Chaos Developer
