Hi all, is there a way to use .bat files or something similar with V-Ray standalone? Currently I've got a file called "mayarender.bat" that I created in Notepad, and when it comes time to do a bunch of renders I'll simply tweak the text in the file (lines generally look like "render -r vray -s 193 -e 320 -b 1 [filepath]"), then all I have to do is hit the Windows key, type "mayarender", hit enter, and I'm off to the races. I like being able to tweak and run a list of multiple renders all at once and edit/save it within a single separate file.
Is there a way to do this with V-Ray standalone that's just as simple, where all I have to do is tweak a simple .bat file then call/open it?
Also do vrscene files render faster than Maya ASCII (.ma) files? Initial tests I've done seem to point to that, but I'm not certain.
