VRayScene class usage tipps
  • VRayScene class usage tipps
    In the API we can find two interesting classes VRayScene and VRaySceneAsset. But there seems to be almost no information in the documentation about how this classes can be actually used. Can anyone give us some tips or links about this topic?
    P.S. Actually we hope that one could load different lightsets or object sets in different VRayScenes and then easily switch between them using mrs_visibility.
    Those are not "classes", those are plugin types (well, those are classes in terms of the appsdk/c++ autogenerated wrapper header for more friendly plugin parameter get/set).
    There is no documentation because 1. they are kinda internal plugins 2. those are standard plugins like any others - all u need to know is available though plgparams / plugininfo (all parameters have a brief help and are mostly self explanatory).
    Both of them are not designed to do what you want; especially if you mean in IPR. So, you may try using them, but no guarantees.
    andrei.izrantcev@chaos.com
    Support Request
      Hello Andrei,
      thank you for info. That's the point, I would like to try them, but it's not obvious how.
      But may be you just have an idea how different assets could be switched fast? Imagine you have two different lightsets (every lightset is basically a group of nodes, materials, bitmaps etc.) and you want to switch between them as fast as possible in interactive mode, how would you do that? Our current approach is to add kind of ID prefix to all relevant nodes. Then the objects can then be filtered out by ID and marked as invisible or visible. It works, but it does not seem to be an elegant solution.
      Alex
