GeomRayserverInstancer User Attributes per instance
  • GeomRayserverInstancer User Attributes per instance
    I'm using the GeomRayserverInstancer to generate millions of instances. Everything works except I can't get user attributes to work.
    I want to assign a user attribute to each instance. ie "rand= (random number from 0 to 1)"
    In the documentation there's different functions for setting user attributes, but it looks like "set_user_attributes_bin", is the one to use.
    The argument for this function is an intList, so I guess I need to convert my CharString to a byte int?
    The documentation also says to refer to "BinUserAttributesWriter". Where can I find information about that?
    Jacob Børsting
    Head of Pipeline @ Ghost VFX
    If you have access to V-Ray SDK it's defined in user_attributes.h.
    It's basically a simple binary packer.
    Code:
    const char attrRand[] = "rand";
    const int atttrRandLen = COUNT_OF(attrRand)-1;
    VUtils::BinUserAttributesWriter userAttrBin;
    // Instance 1.
    userAttrBin.add(attrRand, atttrRandLen, 0.5f);
    userAttrBin.close();
    // Instance 2 no attributes.
    // Instance 3.
    userAttrBin.add(attrRand, atttrRandLen, 0.1f);
    const VUtils::IntRefList uaBin = userAttrBin.toRefList();
    const VRay::VUtils::IntRefList attributes = *reinterpret_cast<const VRay::VUtils::IntRefList*>(&uaBin)
    plugin.set_user_attributes_bin(attributes)
    andrei.izrantcev@chaos.com
    Support Request
      Works like a charm.
      Thanks!
      Jacob Børsting
        Another question.
        Is it possible to switch geometry source per instance? Similar to the shaders/shader_indexes.
        Jacob Børsting
          I'm trying to do the same thing in the 5.10.01 SDK and I don't see
          Code:
          anywhere. Is there a new recommended way of packing the binary data into an IntList?
            Ahhhh, never mind. I didn't catch that it is in the VRay SDK, not the AppSDK. Carry on.
              BinUserAttributesWriter is available for testing now in V-Ray AppSDK nightly builds (currently in C++ only).
