Vantage Livelink
  • Vantage Livelink
    We are testing if we can use the Vray SDK combined with Vantage and we now managed to get it working with even livelink enabled. But unfortunately it stops after several seconds.
    Is there a way to keep this livelink alive forever?
    In tests performed by my colleagues it worked. Can you check with a very simple basic scene? Can you also provide more info?
      THanks for the reply and we already got it working. We had to call the renderer pause function in c#. In that way the render never completes so live link doesn't close.
        Probably it would be better to set VRayRenderer.keepInteractiveRunning to True instead of "manually" pausing the rendering...
