No BSDF parameter specified to material
  • No BSDF parameter specified to material
    I have a problem similar to https://forums.chaosgroup.com/forum/...ified-for-node or https://docs.chaosgroup.com/display/VFBlender/FAQ (In the errors section).
    Here is how the rendered image looks:
    And here is how it should look (the image our designer sent us):
    When rendering the scene with AppSDK, it renders successfully, but one of the materials is rendered as all black. Also, the lighting is off. When I print the debug log, here is what I get:
    Code:
    Dome light resolution increased from 512 to 2048 for light "VRayLight002@light_44"
    Bitmap file "/chaos_datagen/22_06/resources/STR_N1_HDR_B_8K_MED_Performance.88aef8493cdb.hdr" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//bell_park_pier_3k.e9bb3086104c.hdr" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//stone_alley_03_16k.315a57e9b452.exr" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//urban_street_03_16k.2fb1daf09332.hdr" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//RoadAsphaltCleanDoubleLined_Displacement.89e6f991d b60.tif" loaded.
    Using Embree ray tracing.
    Building Embree static trees took 2473 milliseconds, memory used 2319.15 MB
    Embree dynamic geometry tree contains 4 primitives.
    Embree dynamic geometry tree built in 0.73 ms.
    Embree dynamic geometry tree takes 0.00 MB.
    Running RTEngine
    Bitmap file "/chaos_datagen/22_06/resources//Damage2_01.df4b37e14039.jpg" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//Leather_C_HM_2k_lin_srgb.760e9bf87c59.tx" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//L_fender 01.07b734bc3cc2.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//Damage3_01.eb0e6bb6975b.jpg" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//F_Bump_01_Dmg01.b10da92ffdc1.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//Damage4_01.a43725cffa2f.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//Damage4_02.c204e01ae861.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//L_Door_Dmg_1_1001_BaseColor.a81ee14a1bdd.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//L_fender 02.3c30a3012a7d.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//F_Bump_01_Dmg02.64892a680dc3.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//Scratch1.c4b6c7037a32.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//Scratch2.f34012bb0c1c.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//RoadAsphaltCleanDoubleLined_Albedo.9f3056966157.ti f" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//L_fender 03.e6087fd949ec.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//F_Bump_01_Dmg03.b9e7887aff5d.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//F_Bump_01_Dmg04.66af794ca6fa.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//L_Fender scratch 01.26a0cabac5e0.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//F_Bump_01_Dmg05.34d63a245e50.png" loaded.
    Bitmap file "/chaos_datagen/22_06/resources//RoadAsphaltCleanDoubleLined_Gloss.9c365a7c8788.tif " loaded.
    Bitmap file "/chaos_datagen/22_06/resources//F_Bump_01_Dmg06.db3caddc2df8.png" loaded.
    Progressive sampling base buffer memory usage: 374.37 MB
    Noise threshold goal lowered to 0.166667
    Setting up denoiser
    GPAPI: [pickBestOpenCLDevices] No OpenCL devices found
    Failed finding OpenCL devices for VDenoise: [pickBestOpenCLDevices] No OpenCL devices found
    [init] Failed to initialize GPAPI. | [pickBestOpenCLDevices] No OpenCL devices found
    Recalculating denoiser
    Denoising complete in 9.25 s
    Hardware accelerated glare start...
    Segmentation took 10 ms: 0 region(s).
    [applyGlare] GPU accelerated glare failed. | [setBuffer] GPAPI is not initialized.
    Error 1 during hardware accelerated lens effects calculation. Falling back to CPU. Applying lens effects might take longer than usual.
    CPU glare start...
    CPU glare completed. Took 80 ms.
    Noise threshold goal lowered to 0.125000
    Noise threshold goal lowered to 0.083333
    Noise threshold goal lowered to 0.050000
    Noise threshold goal lowered to 0.027778
    Noise threshold goal lowered to 0.014706
    Closing RTEngine (cancelled)
    Max. Mpaths per second: 3.387770
    Sampling level reached: 91 samples per pixel
    V-Ray Interactive render time: 104.42s
    Number of raycasts: 1914307334 (923.18 per pixel)
    Camera rays: 39270658 (18.94 per pixel)
    Shadow rays: 33635191 (16.22 per pixel)
    GI rays: 0 (0.00 per pixel)
    Reflection rays: 38860126 (18.74 per pixel)
    Refraction rays: 11316983 (5.46 per pixel)
    Unshaded rays: 1789360368 (862.92 per pixel)
    Number of light evaluations: 53416881 (25.76 per pixel)
    Maximum memory usage for resman: 28.54 MB
    Number of intersectable primitives: 23206574
    SD triangles: 23206569
    MB triangles: 0
    Static primitives: 4
    Moving primitives: 0
    Infinite primitives: 1
    Static hair segments: 0
    Moving hair segments: 0
    Cleaning up bitmap manager
    Maximum memory usage for texman: 5.43 MB
    The relevant line is:
    Code:
    [MtlSingleBRDF] No BSDF parameter specified to material "Material__120@mtl_0"
    In the second link above, they suggest that my version of Vray is old. This is not the case.
    What might be the reason?
    Can you send us a vrscene file reproducing the issue? It might have something to do with null plugin references in the layered material lists written as 0s... but it would be better to have a scene to inspect and check. Thanks.
      The SettingsGIgi_setting without a space is weird. The main reason for the problem is because you render the scene with V-Ray Next. The scene is exported from V-Ray 5 and it will not work on 4. The reason why the material is black is because it uses the new CarPaint2 material that is not available in V-Ray Next.
