Special characters in texture name
  • Special characters in texture name
    Hello,
    If any special characters (like $, #) present in the texture file name, then while rendering, its not showing the objects.
    I tried exporting as vrscene and run the same in sample application, got same issue.
    My texture file name is like this.
    Is there anyway to overcome this issue or need to change in filename only?
    EDIT::
    When applying as diffuse map only, then its rendering fine. If opacity map is ALSO applied with diffuse, then getting this issue.
    Thanks & Regards,
    Gopi.
    Well, $ is used for udim tags, and # is used for frame number tags internally by V-Ray. So you'd better replace them with something else.
      Hello Stan,
      Please download the file from the link below (contains vrscene file, two texture files and one hdr - for dome light).
      https://we.tl/t-mwd2zoxRSa
      This vrscene file i exported from Max scene where it renders fine. Two textures - one applied as diffuse and another one as opacity map.
      this same vrscene file is not rendering (the object is not visible) when i tried to run with gui-demo application (came with SDK samples). but if i remove the opacity map in vrscene file, then it renders the object (diffuse map texture name still has $ )
      in vrscene file, in the below section,
      BRDFDiffuse a1___Default@mtl_brdf_0_diffuse {
      color=Color(0.5882353, 0.5882353, 0.5882353);
      color_tex=Map__5@tex_0;
      color_tex_mult=1;
      transparency_tex=a1___Default@mtl_brdf_0_combine;
      if i remove this line
      then load in gui-demo application, then, object is visible.
      Regards,
      Gopi.
