Hey guys,
I found that the sharpen/blur layer will not take effect when saved through the renderer, although the effect can be seen in vfb.
Other layers works fine. The SDK version is Ver 6.10.07.
Here is the vfbsettings
Thank you
Code:
SettingsVFB settingsVFB { enable_vfb2=1; vfb2_layers='{"Version":1,"class":"root","properties":{"version":1,"name":"","enable":true,"expand":false,"expandable":true},"sub-layers":[{"class":"chaos.displayCorrection","properties":{"version":1,"name":"Display Correction","enable":true,"expand":true,"expandable":true,"profile":1,"exposure":0.0,"save_rgb_primitives":false,"ocio_file":"","ocio_colorspace":0,"ocio_displaydevice":0,"ocio_viewtransform":0,"ocio_saveinimage":false,"icc_file":"","icc_profile_data":null,"icc_rendintent":0,"blkptconv":false},"sub-layers":[{"class":"chaos.ref.sourcefolder","properties":{"version":1,"name":"Source: RGB","enable":true,"expand":false,"expandable":false,"blend_mode":0,"opacity":1.0,"show_preview":true,"src_type":0},"sub-layers":[{"class":"chaos.ref.lightmix","properties":{"version":1,"name":"LightMix","enable":false,"expand":false,"expandable":true},"sub-layers":[]},{"class":"chaos.ref.composite","properties":{"version":1,"name":"Composite","enable":false,"expand":false,"expandable":true,"blend_mode":0,"opacity":1.0,"show_preview":true},"sub-layers":[]}]},{"class":"chaos.pe.denoiser","properties":{"version":1,"name":"Denoiser(off)","enable":false,"expand":false,"expandable":true,"blend_mode":0,"opacity":1.0,"show_preview":true,"active":false,"preset":2,"strength":1.0,"radius":10.0,"hwAccelerate":true,"denoiser_mode":3},"sub-layers":[]},{"class":"chaos.pe.sharpen.blur","properties":{"version":1,"name":"Sharpen/Blur","enable":true,"expand":false,"expandable":true,"blend_mode":0,"opacity":1.0,"show_preview":true,"sharpen_blur_compute":true,"sharpen_amount":5.0,"sharpen_radius":5.0,"blur_radius":0.10000000149},"sub-layers":[]},{"class":"chaos.pe.lensfx","properties":{"version":1,"name":"Lens Effects","enable":false,"expand":false,"expandable":true,"blend_mode":0,"opacity":1.0,"show_preview":true,"glare_on":false,"glare_size":19.607843399047,"glare_weight":0.0,"bloom_weight":0.40000000596,"glare_threshold":1.0,"filter_rotation":0.0,"saturation":1.0,"hardware_accelerated":true,"cold_warm":false,"interactive":true,"save_glare":false,"bake_glare_weight":true,"create_effects_result_channel":true,"enable_blades":false,"sides":6,"blades_rotation":15.0,"streak_blur":0.20000000298,"use_grating":false,"grating_density":50.0,"grating_length":10.0,"grating_zoom":5.0,"grating_slope":0.0,"grating_strength":1.0,"use_occlusion":false,"occlusion_symmetric":true,"occlusion_percent":20.0,"occlusion_rotation":0.0,"occlusion_arc":100.0,"use_scratch":false,"scr_symmetric":true,"scr_pattern":0,"scr_multiglare_count":1,"scr_density":50.0,"scr_length":50.0,"scr_slope_variance":0.0,"scr_width_variance":0.0,"scr_seed":0,"scr_zoom":2.0,"scr_rotation":0.0,"scr_strength":1.0,"use_dust":false,"dust_pattern":0,"dust_density":50.0,"dust_radius_variance":0.0,"dust_jitter":0.0,"dust_zoom":2.0,"dust_rotation":0.0,"dust_strength":1.0,"glare_use_obstacle_image":false,"glare_obstacle_image_path":"","obst_image_zoom":1.0,"obst_image_rotation":0.0,"obst_image_strength":1.0,"use_filter_image":false,"glare_image_path":"","use_chromatic_aberration":false,"chromatic_aberration":0.10000000149,"camera_type":0,"stereo_mode":0},"sub-layers":[]},{"class":"chaos.cc.constant","properties":{"version":1,"name":"Constant","enable":false,"expand":false,"expandable":true,"blend_mode":5,"opacity":1.0,"show_preview":true,"multiplier":1.0,"color":[0.044449530541,1.0,0.649637579917]},"sub-layers":[]}]},{"class":"chaos.overlay.stamp","properties":{"version":1,"name":"Stamp","enable":false,"expand":false,"expandable":true,"stamp_horiz_align":1,"stamp_vert_align":32,"stamp_color":[1.0,1.0,1.0],"stamp_font":{"version":1,"point_size":10,"family":0,"style":0,"weight":0,"face":"Arial"},"stamp_string":{"version":1,"raw_string":"","final_string":""}},"sub-layers":[]}]}'; }
