V-Ray Benchmark Update - 1.0.4
  • V-Ray Benchmark Update - 1.0.4
    Hello!
    We would like to announce an update to V-Ray Benchmark, version 1.0.4. The new version has an improved UI along with:
    - Comments support for users experimenting with water cooling, over clocking or other mods of their machines that lead to better results;
    - Load the last benchmark results when starting;
    - Double click over configuration copies text to clipboard;
    - Submit OS and NVIDIA graphics driver versions as statistics;
    - Automatic try of different opened local network ports for more robust submission;
    - Fixed regression with UI performance during benchmarking on slow GPUs.
    V-Ray Benchmark can be downloaded from here:
    https://download.chaosgroup.com/?product=57
    Benchmark results can be seen here:
    https://benchmark.chaosgroup.com
    Here you could find a short documentation:
    https://docs.chaosgroup.com/display/VRAYBENCH
    Vassko
    Hi Vassko, I have downloaded the benchmark scene, but when I click "start" the window immediately closes and nothing else happens. I am running Win 10 64 bit and have tried to also run it as admin just in case, but no luck. I have tried it on two separate machines on Win 10 and I run into the same problem. Do you have any advice on what I should try? Thanks!
      Did it closed on CPU test or on the GPU? If it's on the GPU, try to update your graphics driver. If it's on the CPU, please send us (support@chaosgroup.com) this file %temp%\V-Ray Benchmark\vraybench.out to investigate the problem.
        we had the same problem... its was our virus scanning tool... Sophos
        https://linktr.ee/cg_oglu
        Ryzen 5950, Geforce 3060, 128GB ram
