Benchmark causes Blue Screen (while stress testing via V-Ray NEXT works fine)
  • Benchmark causes Blue Screen (while stress testing via V-Ray NEXT works fine)
    My two machines, 7980xe, are both overclocked via the auto settings in BIOS (to 'Extreme'), and both are running at a clock speed of 4.2Ghz.
    My slave PC runs the Benchmark for around 6-7 seconds and then the benchmark UI disappears (i.e. crashes).
    My main PC does the same, only at around 6-7, seconds, instead of the benchmark software crashing, it this PC Blue Screens and crashes Windows.
    I'm running Windows 10 Pro and the latest version of the Benchmark, 1.0.8.
    Any ideas
    Thanks.
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    Is that the CPU or the GPU portion of the benchmark?
    Normally a blue screen means either a hardware problem (overheating, faulty memory etc) or a driver issue (when rendering on the GPU).
      CPU testing only.
      When I then try an actual render (Distributed) - both machines complete that 15 minute render fine.
      (VRay benchmark testing before OC'ing were running fine and reporting times etc).
      It's just strange the an actual render of over 15 minutes works fine (which is quite a severe stress test in itself), but the benchmark fails / bombs out / blue screens.
      Jez
        V-Ray Bench can not cause a BSOD by itself. It is overclock/hardware/OS problem (the fact that it works when it is not OC confirms that).
        Best,
        Blago.
        V-Ray fan.
        Looking busy around GPUs ...
        RTX ON
          Yes I think the OC was too severe, so I’ve tturned it down. Seems the benchmark test is more extreme than an actual render.
          Jez
            The benchmark uses the render after all, so it is the same. There is difference on the things the CPU does for the different scenes, so mostly this is causing it.
            Best,
            Blago
            V-Ray fan.
            RTX ON
              On the Blue screen usually you may find some information about what driver is the cause of the BSOD.
