Does not run on a fresh system install with GTX 660 Ti
  • Does not run on a fresh system install with GTX 660 Ti
    I recently had to reinstall my windows installation and was looking forward to trying out the Benchmark, but after the License screen I only get the splash screen for a second and then the program quits. Same thing happens when I try to run the CLI version - license agreement, installation of files and then immediately uninstallation.
    I run a Win 10 Pro 64-bit, version 10.0.17134.765, a GTX 660 Ti and a Xeon X5460.
    Does anyone have any idea, what the problem might be?
    Same happens here, if you install 3Ds Max which contains Visual C++Libraries, it will run just fine
    or maybe some other missing component. I have never been able to run this tool after fresh install of windows
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Originally posted by eidam655 View Post
      Did you update Windows to the latest update? As Muhammed wrote, Windows updates contain lots of needed components, VC++ libraries including.
      Ivan Slavchev
      SysOps
      Chaos Group
        Hi all,
        Thank you for the answers. I have installed VC++ 2008 through 2015 from this list https://support.microsoft.com/en-us/...al-c-downloads but to no avail.
        I welcome any other suggesions as to what the critical component might be (these could maybe be listed in the future on the Download page as a list of Prerequisities?)
          Seems that I missed this when looking at the topic, but your CPU doesn't support SSE 4.2, so V-Ray Next based application won't run on it. Also, 600 Ti has Kepler Architecture, and Nvidia dropped the Kepler support since 410 drivers, so effectively it cannot be used with V-Ray Next either.
          Ivan Slavchev
          SysOps
          Chaos Group
            Muhammed_Hamed , when was the last time you tried running the application after a fresh install? The latest hotfix release - V-Ray Benchmark 4.10.06, no longer requires C++ Redistributable for Visual Studio.
              Hi daniel.taskoff
              I was using vray-benchmark-4.10.03, I didn't know that there was a new build.
              I will try again tonight on a machine with a fresh copy of windows 1903
              Will let you know how it goes.
              Muhammed Hamed
              chaos.com
