Impossible to submit results
  • Impossible to submit results
    When I click "submit" , IE opens a webpage with this URL https://www.chaosgroup.com/500# and with "something went wrong".
    What should be?
    Anyone else?
    Could you try with latest version here: https://download.chaosgroup.com/down...alone-107-free
    Server does not accept results from some of older versions Benchmark versions now.
      I've download and tested the 1.07 but I had the same error.
      Same as before, finished the 2 benchmarks, click "submit", IE opens the ChaosGroup login, I've inserted the account details I use to download the Vray softwares and then I have the "Something went wrong" page.
        Do you use proxy server?
        If yes - you will need to enable the Bypass proxy server for local addresses option from the LAN Settings window on IE.
        If problem still persist, please send %TEMP%\V-Ray Benchmark\vraybench.out file to support@chaosgroup.com
          I use proxy server and that option is on.
          I think that there are other filters that block the connection.
          Anyway, I'm sending you my results
            Thanks!
            There is a new V-Ray Next Benchmark that you could try - https://download.chaosgroup.com/?platform=47&product=57
              Thank you. I'll try it and I'll check if everything it's ok.
