V-Ray 3.7 available for download
  • V-Ray 3.7 available for download
    V-Ray 3.7 is now available for download from our website. This will be our final official release for V-Ray 3. It includes support for 3ds Max 2020 and some bug fixes.
    Change log:
    New features:
    (*) V-Ray: Initial support for 3ds Max 2020;
    Bug fixes:
    (*) V-Ray: Blowup and Auto Region Selected produce stretched results;
    (*) V-Ray: Decimal separator changes randomly on every export in a specific scene;
    (*) V-Ray: Render to texture overrides elements with black outputs when they are disabled;
    (*) VRayALSurfaceMtl: Endless render when VRayAlSurfaceMtl uses SSS radius value set to 0;
    (*) VFB: Crash when opening VFB in a scene saved with V-Ray Next Update 1;
    (*) VFB: Rendering with region placed over loaded .vrimg, clears the outside part;
    Peter Matanov
    Chaos
    Is this a free update from 3.6 for people that did not yet purchase Next?
    Kind Regards,
    Morne
      Thank you for not completely abandoning support for non-Next versions once Next was released. It would have been easy for you to simply cut off any updates to older versions at the release. I understand that you need to do it at some point, hence "this is the final release", but when you consider that this means that it will run in a current version of max about 2 years past Next's release date, that that's pretty great.
        Of course.
        Best,
        Blago.
        V-Ray fan.
        Looking busy around GPUs ...
        RTX ON
          Awesome, thanks!
            The file says for max 2020... does it work on 19 and 18 or...?
            WerT
            www.dvstudios.com.au
              There is a separate installation for each Max version as always.
              Peter Matanov
              Chaos
                found it... had to tick the 'show all' button... great button that.
                WerT
