V-Ray 5, hotfix 1 available for download
  • V-Ray 5, hotfix 1 available for download
    Hey guys,
    V-Ray 5, hotfix 1 is now available for download from our website.
    I've highlighted some important things.
    Build 5.00.04 (V-Ray 5, hotfix 1) (14 July 2020)
    New features:
    (*) VRayBackToBeauty: Add render element that will expand to all beauty render channels;
    Modified features:
    (*) V-Ray: Simplify the Image sampler options;
    (*) VRayBitmap: View image button should work for .tx bitmaps;
    (*) VRayDistanceTex: Add an option to not compute for the viewports;
    (*) VRayMtl: Raise the default Refraction and Reflection Max depth to 8;
    (*) VFB2: Add keyboard shortcut for Lock Pixel Coordinates ("L");
    (*) VFB2: Support for the color corrections and VRayDenoiser in V-Ray Viewport IPR;
    (*) VFB2: Zoom key combinations support;
    (*) Installer: Progress of V-Ray Material Library download should display downloaded/total size in the installer;
    Bug fixes:
    (*) V-Ray: VRayDisplacementMod's Subdivision not working far from scene origin;
    (*) V-Ray GPU: Activating 3ds Max menus during IPR stops image updates in the VFB;
    (*) V-Ray GPU: Memory leak with VRayDistanceTex;
    (*) V-Ray GPU IPR: Orthographic projection is not rendered properly with RTX;
    (*) VRayClipper: Wrong objects in the exclude list when merged in scene;
    (*) VRayLight: NaN pixels occur with textured adaptive dome light;
    (*) VRayToonMtl: Overlapping MaxScript names of gradient parameters;
    (*) VRayTriplanarTex: Incorrect motion blur;
    (*) VRayVolumeGrid: More noise with Blue Noise Sampling enabled for grid volumes;
    (*) VFB2: Artifacts with Filmic tonemap;
    (*) VFB2: Colorful halo with Lens Effects and positive Lightness values in the Hue/Saturation color correction;
    (*) VFB2: Crash on consecutive V-Ray GPU IPR restarts when selecting different layers;
    (*) VFB2: Crash on scene open when the scene was saved with legacy VFB LUT color correction;
    (*) VFB2: Different convert to composite result if the first light is turned off;
    (*) VFB2: Large color values are not formatted properly in pixel info;
    (*) VFB2: Missing color corrections/post effects on image copied to clipboard;
    (*) VFB2: Resize on region IPR when an image has been previously loaded from history;
    (*) VFB2: Show corrected colors doesn't work;
    (*) VFB2: Switching from OCIO to sRGB and back loses the OCIO settings;
    (*) VFB: "Too many open files" error when loading many LUT files;
    (*) VFB2: Window position can not be saved on a non-primary monitor;
    (*) Installer: Downloading the V-Ray Material Library does not work with network paths starting with "\";
    (*) Installer: The install log is empty when an error occurs;
    Peter Matanov
    Chaos
