V-Ray 5, hotfix 2 available
  • V-Ray 5, hotfix 2 available
    Hi all, there is a new hotfix (2) of V-Ray 5. We had to fit in some more urgent fixes. Changelog follows:
    Build 5.00.05 (V-Ray 5, hotfix 2) (29 July 2020)
    Modified features:
    (*) New VFB: Max Script access for OCIO settings with vfbcontrol;
    (*) V-Ray scene converter: Converting CoronaBumpConverter to VRayColor2Bump;
    Bug fixes:
    (*) V-Ray: An error is printed when rendering with disabled memory frame buffer option;
    (*) V-Ray: Auto white balance renders differently when transferred to camera;
    (*) V-Ray: Missing plugin error when loading scene saved with hotfix 1;
    (*) V-Ray: More noise occurs with Blue noise sampling enabled for grid volumes;
    (*) V-Ray: Crash with a specific scene upon opening in 3ds Max 2021, 2020, 2019;
    (*) V-Ray GPU: Matte objects' primary Visibility is not working correctly;
    (*) V-Ray GPU: The VRayEnvironmentFog parameters (which are last on the list) are applied to all fogs;
    (*) VRayDirt: Ambient + inner occlusion mode results are darker than they should be;
    (*) New VFB: An error is printed when rendering with disabled memory frame buffer option;
    (*) New VFB: Avoid IPR restart on zoom, resize and side panels collapse;
    (*) New VFB: Crash when opening old scene with empty VFB2 OCIO settings;
    (*) New VFB: Window position can not be saved on a non-primary monitor;
    (*) New VFB: Window position is offset on rendering after every scene reset when the persistent settings are saved with collapsed history menu;
    Alexander
    Alexander Kazandzhiev
    V-Ray for 3ds Max developer
