Originally posted by tct70
Vray 1.5 Final????
Originally posted by rivoliOriginally posted by tct70Really................? Mine looks almost exactly the same as the RC version - no tabs here!
I'm using Max 8, does that make a difference?
Thox
Common, Renderer, Render Elements, Raytracer, Advanced Lighting
Just as they did before. I'm using the Max 8 version with Viz 2007.
Originally posted by ThoxOriginally posted by rivoliOriginally posted by tct70Really................? Mine looks almost exactly the same as the RC version - no tabs here!
Thoxwww.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Originally posted by zeronovefinally 1.5 is out, but my problem now is which is the right version?
I'm runnin' viz 2008 (that is 32 bit) on xp64 and I own the dongle?
Once you install the drivers, go on with the installation of the regular 32-bit version for max9.
VladoI only act like I know everything, Rogers.
Originally posted by ThoxReally................? Mine looks almost exactly the same as the RC version - no tabs here!
Originally posted by zeronoveanyone knows what does it mean (from changelog file): "Options for directly controlling the render mode (region, crop, etc.) of the vray VFB"?
Originally posted by vladoOriginally posted by ThoxReally................? Mine looks almost exactly the same as the RC version - no tabs here!
Great job by the way, been very much looking forward to this!
Damnit!!!!!
I've been waiting and checking to try and get the new version for hours and kept getting a 0kb file!
Seems you can't get it if you're using firefox!
Oh well, getting it now through internet explorercan't wait.
I got mine using FF - I just can't get vray and the dongle to see each otherMatt English
Harper Perkins Architects / base2studios
VizDepot.com Moderator
AArch2008/VIZ2008/VRay ONE POINT (WHOOHOO) FIVE!!!
Originally posted by harperperkinsI got mine using FF - I just can't get vray and the dongle to see each other
I'll look into that (again). Thanks!Matt English
Originally posted by BlitterswitchStrangely enough, the reseller told me that there was nothing different between 1.5rc3 and this final version and the only reason chaos are doing this is to move from using the old license system and force dongle use.
....I took that with a pinch of salt. Anyway, cant wait!!!!
install the wibu drivers.
attach the dongle.
run the VRay license server.
Done.
You want to make sure any firewall is off (or has port 30304 free to communicate with the localhost / 127.0.0.1 machine and the network (in case you want the license to be available over it)
There is actually no setup whatsoever to be done to have it work...Lele
emanuele.lecchi@chaos.com
Disclaimer:
