New build available - 1.09.03e
  • New build available - 1.09.03e
    Currently only the Advanced version is updated, the rest are coming soon. This version of VRay is in the form of an installation .exe file instead of a .zip file.
    Build 1.09.03e:
    (*) The VRayLight could crash if the user right-clicks while creating it.
    (*) Saved irradiance maps were not always loaded properly (bug in 1.09.03a-d) causing excessive render times.
    (*) VRay could crash sometimes while calculating irradiance maps (bug in 1.09.03a-d).
    (*) VRay could crash sometimes with VRayLights (bug in 1.09.03a-d).
    (*) Files created with the beta versions of VRay (0.5x.xx) will not load at all from this build onward.
    (*) All of the renderer parameters are exposed through MaxScript (in 3dsmax 5.x). Note that this may cause some incompatibilities with existing MaxScripts - they will need to be updated.
    (*) Added MaxScript methods for loading/saving irradiance and photon maps.
    (*) The Bake3D plug-in file is named differently for each 3dsmax version (Bake3d31.dlu, Bake3d40.dlu and Bake3d50.dlu respectively).
    Fixed the netrender slowdown bug that was killing me last week.
    And it has an installer.
    Vlado - You have made an overworked lad very happy. I'm all choked up.
      www.goo-d.com
      >creating in greece<
        Re: New build available - 1.09.03e
        Vlado, does the EXE detect which DLL's are on the machine and remove any unnecessary ones? I had a terrible time weeding through the renamed DLL's when you changed the "40" to "50" in the dll names. Not a problem for one machine, but with 5 advanced licenses, and 20 render nodes, it became a bit time consuming.
        Are you referring to pre-release Vray 1.0 files?
        Greg Tsadilas
        VFX Supervisor/CG Supervisor
          Why i cant see the new build in the Download section??
          there is not the download link...
          www.goo-d.com
          >creating in greece<
            Could you please offer also a version without installer!
            I have to start it on all render slaves, but just want to drop the files in the root files! It's much easier!
            robert
            I'm registed believe me! Just miss that logo.
              i second that
              Keep Going!
                I third it!
                Alejandro Gonzalez
                alejandro.gonzalez@zerofractal.com
                Zerofractal - Visual Communications
                New Website! www.zerofractal.com
                  Thank you so much for this!!!! No I can finish my script
                  -bill
                  Build 1.09.03e:
                    YES, script for irradiance map...YES !!!![/quote]
