quick update - 1.09.03i
  • quick update - 1.09.03i
    The build resolves some network stability/incompatibility issues which caused V-Ray to hang and even crash during startup or while rendering.
    you guys are the best.
    Natty
    http://www.rendertime.co.uk
      sorry guys but this one wont even instal ???
      going to have to stick with G.....
      Natty
        It installed fine here, and the motion blur rendering freeze issue is fixed.
        Torgeir Holm | www.netronfilm.com
          Yay! That solved my problem.
          - Geoff
            is it just me or something ?
            Natty
              natty: what kind of error message do you get? Make sure VRspawner isn't running while you install.
                havent installed spawner
                it just says all files cant be installed ....... the finnishes.
                ive tried everything
                Natty
                  Have you tried deleting the old files before installing?
                  In the max root folder, delete VRay50.dll and libmmd.dll
                  In the plugins folder delete VRender50.dlr
                    ofcoures........ everything....
                    Natty
                      Then maybe your download is corrupt. Try downloading it again.
                        yeah ...i have done many times.
                        mmm.... i dont know ..im going to stick with G For now.
                        i just hope i dont have these problems with 1.1
                        Natty
                          ok its working now ??
                          i must of downloaded this file 5 times ..... and on the last time the file size was larger ??
                          and installed properly and worked
                          missing packets ??
                          who knows
                          natty
                          Natty
                            I use the h demo. But I cannot enable the "new" VBuffer? It doesn't show, even if I have selected it in the settings. Am I doing anything wrong?
                            /Andreas
                            • #15
                              the VFB has been disabled for a few builds now, it was only available for a short time as a sort of "sneak peak". I think it should be back soon though
                              Eric Boer
                              Dev
