Accessing the beauty pass and saving it from the VFB with maxscript
  • Accessing the beauty pass and saving it from the VFB with maxscript
    How do you access the beauty pass in the Vray frame buffer, with maxscript?
    I need to save each render element with its own unique settings(for example the beauty pass with
    exr at 32 bit, the AO with png at 8 bit, the reflection with tif at 16 bit and so on).
    I think I can go with the render element manager but I'm not sure this is the right way.
    Hints?
    Hello
    There is a MAXScript function
    Code:
    vrayVFBGetChannelBitmap i
    that returns a Max Bitmap object for the specified channel i. Indices start at 1 and the function returns undefined if you specify an invalid index. Index 1 should be the beauty, 2 - alpha etc..
    Some more info here:
    https://docs.chaosgroup.com/display/...ayVFBFunctions
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
