3dsMax 2019.1 – Attaching large amounts of meshes is up to 7 times faster
  • 3dsMax 2019.1 – Attaching large amounts of meshes is up to 7 times faster
    One of the improvements of #3dsMax 2019.1 is “Attaching large amounts of meshes is up to 7 times faster”. So.. I tested it
    http://cganimator.com/3dsmax-2019-1...7-times-faster/
    The enhancement was done for Collapse utility. I think 3dsMax dev choose to enhance this because this is the only attach which keeps
    explicit normals.I test total 4 files. I open the file and attach all geometries.
    The result is… drum roll…
    05_TM_manyLowRes
    Obj:5616 Verts:99,686 Faces: 165,505
    2019 : 3.335s
    2018 : 32.724
    9.81 times faster
    08_Static_Many
    Obj:19913 Verts:2,264,540 Faces: 3,265,430
    2019 : 11.2s
    2018 : 2236s
    199.35 times faster
    bistro
    Obj:2429 Verts:2,766,360 Faces: 3,850.480
    2019 : 9.5s
    2018 : 546s
    57.23 times faster
    EmeraldSquare
    Obj:29596 Verts:9,065,430 Faces: 7,722,170
    2019 : 274s
    2018 : 19980s
    72.95 times faster
    It is actually far better than 7 times!
    Interesting. I never knew about this utility. I've always attached objects from the Attach button of the selected object. This might come in handy with big scenes.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      If it`s anything like previous versions you`ll still have to use `Attach` as Collapse destroys material assignments etc.
        ^yeah I thought collapse did a lost of nasty things, and was also not undoable!?
        Treated it as one of those filthy legacy features not to touch.
          If you want to preserve material ID, use custer attach script.
          If you wantr to preserve the explicit normal from CAD, you have to use this.
