To animate Dreamscape's daylight system
  • To animate Dreamscape's daylight system
    Hi all,
    The task is to make a animation to show the daylighting during different time of a day, it can be easily achieved by using 3dsmax build-in daylight system with VRAY skylight.
    My question is, is there a way to animate Dreamscape's daylight system precisely, as what build-in 3dsmax daylight system does?
    I might miss something, the problem for me is, in order to make Dreamscape's skylight working properly, we need a correct Dreamscape sunlight animation setup even though we exclude all objects from it, because the behavior of Dreamscape skylight has to do with Dreamscape sunlight at least partly.
    Any suggestions?
    William
    TSE
    Create a daylight system. Turn it off, and link the Dreamscape sun to the IES sun. Ouila!
    sigpic
    J. Scott Smith Visual Designs
    https://jscottsmith.com/
    http://www.linkedin.com/in/jscottsmith
    http://www.facebook.com/jssvisualdesigns
      Yeah, should work! I'll try it. Thanks CCS.
      William
      TSE
        It works with standard direct light, except the light multiplier not animated; trying linking the Dreamscape sunlight to build-in daylight, got max errors everytime. Anyone has tried it?
        William
        TSE
