Photmetric lights don't work....???
  • Photmetric lights don't work....???
    I'm using version 1.09.03 and VIZ2005.
    I've created a very simple scene - a closed room with only one light.
    If I set up a normal spotlight from VIZ all works fine, but when I use a photometric light tha scene is completely black. I've even tried to multiply my light with 50000%.
    - Jesper
    are you using photons ?
    Natty
    http://www.rendertime.co.uk
      Nope...... what parameters should I set?
        can you upload a screen shot of the settings and light settings
        Natty
          There is a lot of headlines in the Render Scene dialog box. Which one do you need?
          Can't find the upload function..... is it my profile that has restrictions or is the upload function the same as the image link feature?
          - Jesper[/img]
            well you need some sort of web space to load to then link from that to here ..... send me your file and i'll have a look ..
            Natty
              Your screen shot clearly shows you are using Photons .. IES do work but the multiplyer has to be to high ...
              Use i different calc method like Irr map .. then you will be fine.
              Natty
                The most important thing about IES Lights is that you must draw to scale ... your model isnt ... your walls are 413 feet high lolol .. ies are phisically correct lights so must your model be !!
                Natty
                  I always draw in this scale: 1 unit = 1 mm
                  Is there a way to scale the light or some global scale? - or do I have to scale down my building?
                    first you should set your max units to a scale .. either inches or feet or mm... and then draw as you would expect the walls to be ... 2700 mm for example .. your walls are huge and that is the reason the ies is not working.
                    Natty
                      where do I set my max units to a scale ?
                        under Customize .... then units..
                        Natty
                          trying to merge your scene once you have set the correct units may help ... i never tried it
                          Natty
                            Thanks a lot. I think the scale issue will solve a lot of my problems.
                            In my scene I have set up one light i a completely white room. When rendering the scene has a very white dot on the floor and the rest of the room is very dark. I've set my secondary bounces to 0,9 but it only helps a little. Which parameter am I missing?
