Help needed problem with material & noise
  • Help needed problem with material & noise
    Hi All
    Im having a problem with a certain object a tire which was not made by myself.
    Its comming up with noise on the object no matter what mat I use on it.
    Feel free to take a look at the scene and help me out Im sure its somthing really stupid that im missin!
    http://www.supercreative.co.uk/vray/tire.max
    Its max 6 Vray 1.46.13
    Thanks for your help.
    Simon
    Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
    set your Raytracing Seconday Ray Bias to .001 and all renders fine.
      even better would be to use a shell modifer, as the ray bias fix causes some different image errors.
        So whats causing the prob percydaman?
          Prob solved anyway cheers percydaman
            Hi percydaman
            How do I need to use the shell mod to solve this?
            Thanks
            Si
              if raybias is fixing it, it sounds like you have coplanar faces
                Hi Dynedain
                Whats that mean faces on top of each other?
                Si
                  it means having two faces that exist in the exact same location
                  so when it comes time to render, the computer gets confused as to which it should be displaying
                    Thats as I thought I will take a look at the model.
                    Thanks
                      Coplanar faces appears to be the problem indeed. If you edit the mesh you can delete one face and there is another right behind. It might be worth your time to clean out the extra faces from one band of the tire and then do a circular array to make a new tire.
                        Yep your right PixelJockey some or most faces are doubled up which causes the problem.
                        So its down to the crap model not a V-ray prob, "not produced by me I must add"
                        Thanks
                        Guys
