Do any of you do other work while rendering?
  • Do any of you do other work while rendering?
    Hi all fairly new to the forums,
    I have a plan in my head for what to do in terms of my workflow- I am planning on getting a machine with something like a 7920x and allocating 8 of the cores to rendering solely (right now im on a 4 core xeon) and the other 4 cores to photoshop etc.
    I will also hopefully have a 1080ti which will be dedicated to rendering and a P2000 for all other tasks.
    Having 2 machines isn't really an option and it is not very ideal doing it like this I imagine but im wondering if anyone else does something like this.
    Any insight would be greatly appreciated.
    Hi there,
    My main machine has an i9 7900X overclocked to 4.6 GHz, 128 GB of RAM and two 1070tis and one 1080ti
    Using it for similar to what you said, it works without issues. 2 cores/4 threads are usually enough for photoshop or modeling in Modo or Maya while having Vray rendering using the 16 other threads.
    Same for Vray GPU, it works just fine.. I use one card for viewport/windows performance and 2 cards for rendering.. There is no UI or Viewport lags
    I use the 1080ti for viewport performance now, but even with something like a 1060 6 GB you should be fine.. This is very popular for GPU rendering
    Don't get the P2000 though, you better get a 1060 6 GB or a 1070 for the same amount of money and it will be faster/have more VRAM than this Quadro.
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Yep, I work very much while I am rendering. It was a problem for a while, but that was all worked out with some command line stuff.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        I sometimes work in another instance of Max or in Photoshop while rendering. Just make sure you have enough RAM.
          Bobby, can you elaborate on the "command line stuff" I typically reduce cores in the task manager but from what I understand that is the incorrect way to do it
            The below used to work for me, but not since the latest V-Ray NEXT update. I tried it again, shortly after I upgraded, but it didn't work this time. I tried it again today, but I haven't rebooted yet to see if it work this time.
            Here are some Windows command line tools I found online. You have to elevate the cmd to an admin before you run it.
            set /a CORE_COUNT=%NUMBER_OF_PROCESSORS%-1
            setx /M VRAY_NUM_THREADS %CORE_COUNT%
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Can't put my finger on it, if it's new max or new VRay, but it's nearly impossible to do anything else while rendering. It definitely was NOT like this with VRay 2.4. Things seem to have gotten worse in this regard.
              Kind Regards,
              Morne
                You can try to bring V-Ray 2.4 on your current OS and you will see that unfortunately it behaves the same. Something changed in the OS/drivers lately that brings this behavior.
                If removing one core doesn't help - you could try removing two..
                Yavor Rubenov
                V-Ray for 3ds Max developer
                  Try this, but using the Windows PowerShell (admin) and see if it works for you.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    I can barely use chrome while rendering which i know is obviously a case of the resources being exhausted but when i used to used keyshot at uni I could set the core usage in software which was super nice, really wish something like this was implemented into vray.
                      It already is - you can use the environment variables posted above to set it for the whole system. If you prefer you can also set it for specific scene with the following MAXScript:
                      Code:
                      renderers.current.system_numThreads=sysInfo.cpucount-1
                      which will reduce the number of threads with one.
                      Yavor
                      Yavor Rubenov
                        Code:
                        Yavor
                        Thanks for that info, il give it a go in future, however i meant more in the sense of a drop down menu/ button option just for ease of use. I suppose i would have to add that to the wishlist though :P
                          I`ve wandered into the 2019 Vray render freeze. I never had it with 3.6 nightlies before but recently I updated my pc from a Quadro 4000 to a 1070ti and in 2019 with 3.6 nightly the freeze was ridiculous, completely unusable. I`m still on Win7 and I always set 3dsmax to low priority in Task Manager but that wasn`t enough, I also had to tick Low Priority in Vray as well which fixed it enough to not freeze, something I didn`t have to do in Vray 3.4. I`m not putting my Quadro back in just to test but I wonder if changing my GPU had any impact or if something else in the more recent 3.6 nightlies has changed because it never froze before with earlier 3.6 nightlies and my old Quadro card ?
                            I used to be able to do a lot while rendering, while using all the cores. Now in 3.6 my system just hangs constantly and I'm not planning on setting a few cores to do 'nothing' what's the point of having a multicore system then. I don't understand how software can go backwards and the solution is to disable a few cores.
                            A.
                            www.digitaltwins.be
                            • #15
                              My understanding is, it is an OS thing and not a V-Ray thing. I posted some escalated CMD code, which solved my issue. If you search Freeze, you should be able to find it.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
