3GB switch causes HD to react weird?
  • 3GB switch causes HD to react weird?
    While testing other stuff, I noticed something weird. When I save a max file, my system freezes for a few seconds.
    At first I thought it was winamp, because my music stopped for a few seconds also. But it was freezing without winamp also...
    It happens even with the simplest scene.
    When I startup windows without the 3GB switch, everything works fine (but then I don't have the 3GB switch, and I need it!)
    This only happens to max files, I can save photoshop or whatever other file just fine.
    Any idea why the 3GB switch would cause this behavior?
    I know all drivers must be winXP certified or something, and I know for sure this is not the case here. It's impossible to have only that kind of drivers, even my monitor drivers gave me this warning I believe.
    Kind regards,
    wouter
    Maneswar Cheemalapati described on the discreet board that some systems need the additional /USERVA switch to work properly with 3GB. I don't know if this is the case with your system ...
    The thread was located in the hardware forum and was called "WinXP & Max 7".
    Hope that helps,
    Andrea
      I think .. should be this:
      http://support.discreet.com/wb/defau...fid=234#196241
      Someone is speaking also about more switches with /3gb
      like: /fastdetect /3GB /sos /maxmem /userva
      or this also:
      http://support.discreet.com/wb/defau...fid=234#195493
      I'm interested also, so better i read carefully all posts.
      Workstation Core i7 6900 - 32GB RAM - GeF970
      Dual Xeon E5-2630 - 32GB RAM
