IPR - locked to camera
  • IPR - locked to camera
    Hey guys,
    So when I'm using IPR - the render is of the active view. So if I have to change something in the top view say, my IPR becomes the top view. What I'm looking for is to lock the render to the camera view regardless of active view. Is that possible? I did find a bit in the docs (https://docs.chaosgroup.com/display/...Buffer+%7C+VFB) that says if you right-click on the IPR button you will get a list of cameras to render. When I right-click I get nothing. Was this removed recently? Any suggestions on how to lock the render?
    Thanks
    Daf
    Go to the desired view/camera and open Render Setup (F10). Below the big Render button you'll see a lock icon. Press it and now no matter what viewport you're in Vray will render the locked one.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      Perfect! Thanks, Alex!
