VRay Next Update 1 _IPR Feedback
  • VRay Next Update 1 _IPR Feedback
    Hi everyone
    let me start by saying I'm super happy with the latest update so thank you very much for all the team!
    I'm mainly interested in IPR as that what will really affect my workflow. It is already great but here are my notes/requests /questions : ) )
    1- I've noticed that GPU IPR to be a bit more fluid and we have settings like Undersampling / IPR rays per pixel to have more control. would it be possible to have those for CPU IPR too?
    2-In GPU IPR and especially for interiors where the GI is dominating there seem to be black areas that clean gradually while in CPU IPR we don't have those areas. is it because of light cache in CPU we don't get that? (image attached rendered for the same time limit)
    3-Region renders as I've mentioned on other threads still start from scratch on IPR CPU instead of continuing cleaning like the case of IPR GPU.
    5-IPR in the viewport is great but I would love for future to have a bit more control like what we have in VFB. Seeing the Color correction, pick a focus point, render region are the main features for me. if it is possible to hide all the lights/helpers/shapes that would be nice to have cleaner viewport while having them visible in other viewports for editing. I know that's not the purpose of viewport IPR.In other words, what I'm asking for is having what we had with active shade before, but with the new interactive viewport if possible.
    6- There are 2 cases that IPR doesn't update and these I use like 50 times every day =D :
    A- Adding any object to exclude list for Override Mtl under global switches doesn't update in IPR.
    B-hiding Geometry using SHhift +G will hide them in both IPR and viewport but when I unhide them IPR doesn't update.
    For both cases I have to stop IPR and run it again as "Refresh" doesn't help here.
    7- A small annoying bug I found with IPR ..try to click " Show correction controls in VFB while it is in full screen and the menus on the right won't show up till you minimize or move the VFB which will force IPR to refresh. the workaround for this is to disable Fit IPR resolution to VFB and set it to match the full-screen resolution, but again for the final render, I will need to change it
    As you can see most of these points are really simple and IPR is already great now, but I thought I should share them with you.
    Nawras
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
    We'll consider it.
    You can experiment with LC in V-Ray GPU IPR with the maxscript command - renderers.current.ipr_forceBruteForceGI=false . Also you can raise the IRP rays per pixel. We are looking to improving this internally.
    We'll see what can be done about this.
    Some things like the CC and render region might be implemented, but for the rest we are limited by 3ds max. Don't forget that this is 3ds max Viewport and it's a viewport, not an image buffer.
    Will bump the issue in the system.
    Will add it in the system.
    Thanks for the feedback !
    Peter Matanov
    Chaos
      Thanks for the detailed response !
        Really cool to know that it is possible to use lc with GPU IPR
        savage309 Is this WIP for an upcoming release? or can I do this in Maya?
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          I don't really know, the Maya guys will know better.
          yolov Mihail.Djurev
          Best,
          Blago.
          V-Ray fan.
          Looking busy around GPUs ...
          RTX ON
            I don't recommend playing with the light cache for IPR with V-Ray GPU just yet; it's still WIP and there are unresolved issues yet - f.e. with the adaptive lights. The option is hidden for a reason
            Your observation about the black areas is correct though - the CPU uses the light cache which improves the GI sampling. The GPU IPR is brute force only and it takes more samples to get the same result. I'm hoping that at some point we can enable the light cache for GPU IPR by default.
              One of the main reasons I'm still not doing GPU rendering. IPR previews with GPU always come out dark and don't correctly represent the final look as IPR CPU does no matter how long I wait for the GPU to clear the noise. I'm always wondering how are people doing interiors with GPU. Do they constantly rerender when they do changes like we did before IPR was invented? I'm curious to know. I can never go back to not using IPR again.
              Aleksandar Mitov
              www.renarvisuals.com
              office@renarvisuals.com
              AMD Ryzen 9 9950X 16-core
              96GB DDR5
                GPU rendering is all about IPR interactivity/speed. Vray GPU does this really well and many people have been using it in production.
                Vray's GPU IPR uses BF+BF(which is the case with RS, Octane and others) but it still can use adaptive lights..and, having the right hardware, it is very fast and feedback is almost instant..The experience is quite different compared to using IPR on CPU
                In the testing above, M.Max used a single GTX 970 (BF+BF) vs 2x 2696V4 (72 threads and BF+LC) Still he talked about the GPU IPR being more fluid.
                I do all my rendering on GPU since 3.6 and many other people have been using it in production, quality has been really good so probably you are doing something wrong.
                https://www.behance.net/gallery/6628...cans-triplanar
                https://www.behance.net/gallery/62131663/Porsche-GT3-RS
                https://dabarti.com/portfolio/bugs-theater-cgi/
                Muhammed Hamed
                chaos.com
                  I'm interested to see what I'm doing wrong. With the GPU in my signature I'm getting extremely slow light evaluation compared to IPR CPU (6 minutes vs 25 seconds). This makes my GTX 1080ti 14.5x times slower than my 1950X in IPR GPU (at least in this scene). Please check the screenshot below and notice how much longer IPR GPU took to resolve the noise to CPU IPR levels. All GPU settings are at their defaults. Click image for larger version  Name:	vray_IPR_CPU_vs_GPU.jpg Views:	1 Size:	115.0 KB ID:	1019618
                  IPR aside, I'm getting slow GPU production rendering performance compared to my 1950X too. Compare the 2 screenshots below. Both were set to resolve to Noise threshold level of 0.015. 1950X took 25 sec. and 1080ti took 3 full minutes. This time difference makes the 1950X 7.2x times faster than my 1080ti. This doesn't seem right. Again, I've not change ANY setting, everything is left at default except for noise threshold which I set the same for both.
                  Click image for larger version  Name:	vray_nextUpdate1_CPU_vs_GPU.jpg Views:	1 Size:	168.4 KB ID:	1019623
                  Aleksandar Mitov
                  96GB DDR5
                    For the IPR specifically, on the CPU we use the light cache while on the GPU we use brute force, which would explain the large difference in render times for IPR. At some point we will enable the light cache for GPU IPR as well.
                    The production rendering case is more interesting and I would like to take a look, if possible?
                      yolov Mihail.Djurev
                      Best,
                      Blago.
                      No, unfortunately this cannot be done in Maya at this point.
                      Alex Yolov
                      Product Manager
                      V-Ray for Maya, Chaos Player
                      www.chaos.com
                        Thanks Alex and Vlado!
                        I will wait until it is officially released. Im quite happy with the GPU IPR
                        And considering Octane 4 and RS are using BF+BF for their IPR, I'm looking forward to light cache being implemented Into Vray's GPU IPR. It will be a massive speed boost.
                        Even now I prefer working with Vray's IPR for things like debug shading and the VFB.. and speedwise, The IPR is as fast as competition..
                        Muhammed Hamed
                        chaos.com
                          In my testing, noise threshold doesn't match between CPU and GPU
                          Usually I have to use .005 for CPU to match .015 on Vray GPU
                          I would recommend you benchmark your 1080Ti as well and have low GPU thread priority off when you are rendering with Vray GPU.
                          And for this testing you might want to test render something that takes 5 minutes or longer.. In your screenshots you can see the reflection on TV and lighting on left wall, not matching the CPU render, so you might want to make both scenes as close as possible. You should probably use Bucket mode for both engines as well.
                          I'm using 3x 1080Tis and an i9 7900X @4.8 GHz.. This setup has been way faster than rendering on CPU alone, and with Hybird I can use my CPU in rendering as well.
                          Muhammed Hamed
                          chaos.com
                            Okay thanks for the clarification.
                            I don't mind using BF for IPR now ..actually in the other renderer that we use (Corona ) there is an option to "Force Path tracing" for IPR to avoid the cost of re-computation to the UHD cache which comes handy in some cases ,so having such option could be good idea too imo .
                            • #15
                              Alex_M the render time difference is so different than what I see usual! Here are 2 images rendered on the same rig (2* xeon E5 2650 v3 + Gtx 970 ) using Noise threshold 0.015 while everything else is using default settings (both using Bucket)
                              Next (CPU ) : 14m10sec Next GPU :16m 6sec (Hybrid) so it is very near.
                              There are few differences in the images for this specific scene .mainly the bump strength and forest pack random sample animation thats seems to be off in GPU (I will check with itoosoft support ).
