Good day Everyone
I have question regarding right usage of render limits in GPU NEXT renderer.
As far as i can see there's time/samples/noise levels limits, however, only time limit makes total sense, render stops when a certain time limit is reached.
When I set noise level limit and time limit (let`s take for example default settings), then even if noise level is reached it still renders something untill time limit is reached, and IF I set time limit to zero, it still takes some (quite a lot of) time to "render" something.
And Samples Limit does not works logically at all, let`s say, I saw on previous frame, that render after 3 minutes and 800 samples is OK, so I can set samples limit to 800 and ignore other limits, but it does not works like that at all...
so can anyone guide me through that questions?
