compatible RTX cards with the latest 4.0xx Vray?
  • compatible RTX cards with the latest 4.0xx Vray?
    Hello guys
    I bought two new nvidia RTX cards. I guess I should purchase the 4.0xx vray right?
    Can anybody confirm that these new cards are compatible with the latest vray, otherwise I won't purchase it.
    Thanks!
    CPU: 5930K
    GPU: 3x970 GTX,
    MEM: 32 GB ram
    SSD
    So it turns out that it works! I have an RTX 2070 card, which unfortunately have no sli connection, but I'm planning to purchase another one, can Vray work both of the card without SLI or Nvlink? If not, I will change it to a 2080 one.
    CPU: 5930K
    GPU: 3x970 GTX,
    MEM: 32 GB ram
    SSD
      It will work but with 2 x 2080 (or even better 2080 Ti) you can combine the memory of the cards.
      Peter Matanov
      Chaos
        Thanks, is that the only benefit? Wouldn't it be faster as well?
        CPU: 5930K
        GPU: 3x970 GTX,
        MEM: 32 GB ram
        SSD
          2080ti is faster than 2080 and 2080 is faster than 2070, of course :
          Best,
          Blago.
          V-Ray fan.
          Looking busy around GPUs ...
          RTX ON
            So it turns out Vray 4xx doesnt work with two 2070 RTX cards. It only sees one card not the other one.
            CPU: 5930K
            GPU: 3x970 GTX,
            MEM: 32 GB ram
            SSD
              Check if other tools can see them, f.e. MSI Afterburner. V-Ray GPU doesn't have any problems with rendering with multiple cards (no matter what they are) as long as the system is running properly and the drivers are reporting the right number of GPUs in the system.
              Peter Matanov
              Chaos
                My bad! It works!!!!! Sorry about my last comment!
                CPU: 5930K
                GPU: 3x970 GTX,
                MEM: 32 GB ram
                SSD
                  No problem, happy rendering
                  Peter Matanov
                  Chaos
                    The 2070 rtx have no possibility for SLI connection?
                      No. This is a hardware limitation. It just doesn't have the connectors and all that on the board.
                      Best,
                      Blago.
                      V-Ray fan.
                      RTX ON
                        Originally posted by Dini009 View Post
                        Hello guys
                        Thanks!
                        I have been using 2x 2080ti since they came out and it works perfectly with Vray. Just buy it and you won't regret it.
