can animate the On / Off switch of V-RayLight (Dome)?
  • can animate the On / Off switch of V-RayLight (Dome)?
    I understand that you can not handle multiple DomeLights even with V-RayNextUpd 1.1.
    But can animate the On / Off switch of V-RayLight (Dome)?
    I want to switch the effective dome light during animation.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    maybe try changing the multiplier to 0
    Kind Regards,
    Morne
      if you are using it with a map in, you could use a mix map in the domelight, and keyframe the mix from one map to the other over 1 frame. that way youd only need 1 domelight.
        thank you for the advice.
        The solution seems to be to animate Map.
        oakcorp.net
        v-ray.jp
