adaptive dome light WIP - not working with light select pass
  • adaptive dome light WIP - not working with light select pass
    The option speeds up rendering with HDRI a lot, is some test cuts the render time in half.
    But it doesn't work with light select, which for animation is not ideal, as there is lot of compositing with light select passes.
    I split it to direct and indirect, direct is clean, but indirect has a lot of fireflies all over the image.
    Just saying as exp on this, since it is WIP still.
    cheers
    Thank you for the feedback. Light select should work as expected in the latest V-Ray Next. Could you update V-Ray and try again.
    If you are still having issues, could you provide us more information and an example scene to support@chaosgroup.com.
    Martin Minev | chaos.com
      Hello Martin,
      I am having latest Vray next update installed, since the release.
      The issue remains.
      I will try to collect the scene.
      Thanks
