VRay Swarm for 3DS Max
  • VRay Swarm for 3DS Max
    Hey guys,
    1 - Is VRay Swarm coming to 3DS max?
    2 - My limited understanding of it is that I'd be able to utilise (hopefully all of) the PC's in our office for rendering - but that it currently isn't available for max?
    3 - (Hypothetically) Will these PC's still render even if their specs aren't amazing? It isn't uncommon for me to have a scene that requires 40+Gb RAM. Would this run on say a machine with 8Gb? Does the swarm take care of this?
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
    good questions. i was wondering the same thing.
      Still wondering. Do I need to take out a support ticket or something?
        What's happened to these forums?
          [QUOTE=Macker;n1030341]Hey guys,
          1 - Is VRay Swarm coming to 3DS max?[quote]
          No idea.
          You'll need to have a pc ready to accept an incoming connection of that type, and the subsequent work. Or it'd be a hack on said machine.
          No it won't. It's a simpler approach to DR, not magic.
          GTC is on, and most of the people active on these forums are busy and on a different timezone than yours, with slightly different day-to-day priorities for a couple of weeks.
          Lele
          emanuele.lecchi@chaos.com
          Disclaimer:
            So it offers no tangible benefits to DR then (if it were to port to max)?
              Well no rendernode licenses needed. Atleast thats the case for sketchup.
                SWARM is just a DR manager that adds a GUI and some other automation, so you'd still need licenses to render on render nodes etc.
                It's not in 3dsMax, because unlike other V-Ray versions where a .vrscene file is exported and rendered with V-Ray standalone on the slave machine, V-Ray in 3dsMax renders via 3dsmax.exe on the render slaves.
                You can use the usual 3dsMax distributer rendering setup - it will be no less effective than a DR setup with another V-Ray version, regardless if SWARM is used or not.
                Ivan Slavchev
                SysOps
                Chaos Group
                  My mistake, didn't realise you needed RN's for the swarm...*groan*
                    It would be handy to do this with MAX/Deadline. I want to setup a portion of our farm as one giant DR group that will auto divide itself to a min/max. So when only one person is rendering all the machines are working on it, when 10 people are it divides by 10, or to whatever the min/max limit is. Without the user needing to intervene or set any other limit than min/max. Perhaps that can be an admin override, min of 3 machines (or cpus) and max of 20 or something like that.
                    "It's the rebels sir....They're here..."
