Can't find 'Multiple Scatter' settings in VRayFastSSS2 within Max 2019
  • Can't find 'Multiple Scatter' settings in VRayFastSSS2 within Max 2019
    I can't find 'Multiple Scatter' settings in VRayFastSSS2 within Max 2019. I'm doing some tutorials that are Maya based and they use 'Multiple Scatter'. If I look in the Chaos Group V-Ray Max Documentation, it mentions it but not how to enable or find it. So I think it is implemented in Max. I just can't find it in the Material's parameters anywhere.
    Do I have to do something special to enable/expose 'Multiple Scatter' options?
    V-Ray 6.20.06, 3ds Max (3D Studio thru Max 2025), GIGABYTE X570 AORUS Master Motherboard, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, NVidia RTX 4090, Space Pilot Pro, Windows 11, Tri-Monitor, Cintiq 13HD
    Autodesk Expert Elite Member
    I finally found something. 'Multiple Scatter' has been removed from Next. Problem solved.
    Here's what I found: "
    • The Prepass-based and Object-based multiple scattering modes of the VRayFastSSS2 material have been removed for causing compatibility issues. The material will render in purely raytraced mode for the multiple scattering effect, including when rendering scenes saved with previous versions of V-Ray. "
