3ds vs Standalone - displacement
  • 3ds vs Standalone - displacement
    Hello guys.
    We are working on a new project, and i wish to be able to render complex scene using vrscene (to be able to use a Linux renderfarm) but i have noticed différents between normal rendering and vrscene rendering.
    Here's one easy to reproduce, with a simple checker in a displacement + vray Sun.
    Rendered with 3ds 2020, vray 4.10.03
    Click image for larger version  Name:	Vray_displacement.jpeg Views:	1 Size:	765.4 KB ID:	1031691
    Click image for larger version  Name:	VrayStandalone_displacement.jpeg Views:	1 Size:	780.8 KB ID:	1031690
    Is the Vray Cloud supported feature match to the Vray Standalone supported features ?
    https://docs.chaosgroup.com/display/...orted+Features
    Thanks !
    -p-
    http://tatprod.com/
    I'll check this and get back to you
    Miroslav Ivanov
    Chaos Cosmos
      Can you post the scene? Looks like in 3ds Max the scene uses 2D displacement, but in the standalone the 3D displacement method is used. This could be a bug in the exporter, but it would be best to check the scene to confirm.
        Here's the .vrscene file.
        For your information, the image i made was not a vrscene exported but a vray Cloud preview. (is the vrayscene created by the cloud submiter is saved anywhere ?)
        http://tatprod.com/
          Up !
          Tested with 4.20.01 (& 3dsmax 2020.1)
          3D displacement is still not rendered correctly in the vrayCloud preview.
          2D displacement is pixel perfect between local rendering & standalone. I really need this for 3dDisplacement, it's a critical point for rendering animation in cloud
          Thanks !
          http://tatprod.com/
