select color of material in VrayMtlID?
  • select color of material in VrayMtlID?
    Is there a way to select the color of the various material id's for the VrayMtlID render element ouput?
    Hello,
    Currently there is no option for this. Each ID is storing an integer value within a EXR file, or vrimg. I will attach an image showing the colors for all material IDs.
    As a workaround you can use a VRayExtraTex render element with VRayMultiSubTex to create a mask, but here you have to specify an object ID for each object, or you can use the other modes of the VRayMultiSubTex. Also you will have antialiasing.
    http://ftp.chaosgroup.com/support/sc...5_16-30-29.jpg
    Martin Minev | chaos.com
