Denoising animation sequence
  • Denoising animation sequence
    This week at last I upgraded to Vray Next.
    So today I decided to try the denoising tool as I want to denoise an animation sequence.
    I add the Denoise Element and under Mode I select "Only generate render elements"
    I save the sequence as an open exr and add the VrayDenoiser element under render elements tab.
    I render the sequence and I load the VrayDenoiserTool and select the sequence.
    After I hit denoise I see that there isn't any denoise applied on the image. It just makes a new sequence but with the same noise.
    What am I doing wrong?
    Dual Xeon 2690 v3, Asus Z10PE-D8 WS, 64GB, SSD Win10, TitanX(Maxwell)
    Ok solved it.
    I had to enable Vray Raw image file.
