So with the new version of Vray there's a new algorithm for sampling lights - Light Tree. My question is should I use this instead of Adaptive Lights and when? Also, why is Adaptive Lights still the default if Light Tree is newer?
Light Tree or Adaptive Lights?
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
I think light tree is inside adaptive lights so you don't need to change anything. Always use adaptive lights and it should work fine for the most part.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
Then why is there Light Tree option to chose from?Aleksandar Mitov
96GB DDR5
To replace the uniform probabilistic method.
Feel free to test the light tree, though.
Defaults are your safety net should things go sideways.Lele
emanuele.lecchi@chaos.com
Disclaimer:
Ok, thanks!Aleksandar Mitov
96GB DDR5
I did a test for both adaptive and light tree and for this specific scene light tree was better in terms of quality (no flicker in reflection ) .
This one is rendered using the default Adaptive
(Full HD NT 0.01 3-4 min)
https://vimeo.com/341181323
This one is using light tree
https://vimeo.com/341757656
(HD NT 0.005 6 min)
I probably will need to do another test with the exact settings for the adaptive to be sure about render time and if adaptive was the real reason behind the flickering for sure.
Simply, I love to put pixels together! Sounds easy right : ))
Sketchbook-1 /Sketchbook-2 / Behance / Facebook
- Likes 1
