Can I add The Light to Trace Set in VRay Next?
  • Can I add The Light to Trace Set in VRay Next?
    I want to control reflections on a per-object basis.
    It does not work when added with the vrayAddTraceSets command.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    If you wish to add trace sets to an object via MaxScript, use the following commands in the MaxScript Listener:
    m=vrayAddTraceSets $ --this would add trace sets to the selected object; you can replace $ with $Sphere002 to add an object for example
    showproperties m --this shows the available properties of the trace set
    m.reflect_exclude=#($VraySun001,$VrayLight001) --set light names in the brackets
    m.refract_exclude=#($VraySun001,$VrayLight001)
    m.reflect_exclude_type=0 --0 is exclude; 1 is include
    m.refract_exclude_type=0
    Example script, which includes only the sun in the reflections of an object:
    m=vrayAddTraceSets $Teapot001
    m.reflect_exclude_type=1
    m.reflect_exclude=#($VraySun001)
      thank you for the advice.
      I said vrayAddTraceSets command doesn't work.
      This means that VRayLight is not excluded in Exclude mode.
      In Include mode, VRayLight becomes invisible (opposite meaning), but nothing is reflected.
      Probably a bug.
      Confirmed with V-Ray 4.20.01 3ds Max 2020
      oakcorp.net
      v-ray.jp
        Another question
        Can I exclude V-RayLight using Trace set when Glossiness is 1.0 or less?
        There is no way to disable V-RayLight's Fake Spacular on the material side.
        oakcorp.net
        v-ray.jp
          My bad, the solution used to work for V-Ray 3.6, however, it seems that it does not in V-Ray NEXT. Thanks for the report. I have forwarded the information to our developers for further analysis.
            I had the same issue few months back ,and I've posted a scene too with comparison if that will help..please higher the priority of this
            https://forums.chaosgroup.com/forum/...exclude-lights
            Simply, I love to put pixels together! Sounds easy right : ))
            Sketchbook-1 /Sketchbook-2 / Behance / Facebook
