Hi, I notice that by default the VrayLightSelect is set in Full mode. Is there any way to set it to an other option for example direct illumination?
Thanks, Alessandro
If I understand you correctly, just change it from the mode's drop-down menu option. When the render is done you should see it. Rename it properly just in case.
Hi, and thanks for your answer.
Sorry if i do not explain clearly in the first post.
I use a script that generate LightSelect render elements for all the lights in my scene. It will be useful for me that vray generate them in direct illumiation by default so i do not have to do it one by one or forgot to do it.
Thanks for the support.
