Converting V-Ray Scene to standard Scanline scene with materials
  • Converting V-Ray Scene to standard Scanline scene with materials
    I'm having some problems with third party software. It crashes every time I open Max scene with V-Ray materials on it. I tested with simple one object scene and noticed, that replacing V-Ray materials with standard materials did the trick. I wonder if there's a way to convert complex Max scene without having to re-create each material manually as standard materials?
    There is a universal material convertor. Also, doesn't MAX itself pop up a convertor?
    https://www.3dstudio.nl/webshop/prod...rial-converter
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Thanks Bobby,
      I tried to order one license for me, but their webshop refuses to work with every of installed browser.
      Anyway, I was asked to convert very complex scene to FBX to be used in Unity. After some polygon reducing, I generated the file by built in Max Game exporter. I decided to do another try with Polytrans reducer, but my BDF files crash Polytrans because of V-Ray materials. It works fine when I tested singe object where I changed standard material. However I'm looking for one click solution for converting a complex scene.
      What would be the preferred workflow for sending complex Max scenes to Unity without having to remodel everything?
        Since I got no answers from that webshop, I created whole new material library with Standard materials and removed every sign of V-Ray on that scene. It's still crashing and I was told to "disable" V-Ray, when sending scenes to that geometry reducer. What would be the recommend method for doing so?
