Removing denoising from the effectsResult channel in VFB. How?
  • Removing denoising from the effectsResult channel in VFB. How?
    Sometimes I add a denoiser render element and later when the render finishes I realize that I don't want to save the denoised version, but I want to keep the lens effects. How do I do that when both effects are merged in the channel called "effectsResult"?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    In such cases, what you can do is save the RGB (which isn't denoised and contains no lens effects) and re-apply the lens effects to it via the 'vdenoise.exe' tool.
    Refer to this post for the application method: https://forums.chaosgroup.com/forum/...47#post1045947
      Ok, I'll try. Thanks for the tip! I hope this can be improved with VFB version 2.0 so that the user can choose which effect to apply on top of the image.
      Aleksandar Mitov
      96GB DDR5
