Rocks
  • Rocks
    I am starting a project tomorrow with some rocks. How in the heck should I approach this?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    have you looked at quixel megascans..you might be lucky getting a rock outcrop 3d mesh of some sort.
    e: info@adriandenne.com
    w: www.adriandenne.com
      Yeah, some combination of 3D scanned rock materials and models should probably do the trick.
      It likely won't be at all accurate to the location, it'd just be a generic rocky lump. If they want accuracy, I'd say you need to do photogrammetry of the actual location.
      __
      https://surfaceimperfections.com/
        reckon megascans will be pretty useful here, might need to adjust teh colours a bit but otherwise will look great
          I didn't get the photo of the site until well after I quoted the project, which rubs me the wrong way. The project is one exterior view, so I am going to try and get a high-resolution photo of the angle. We'll see how it goes. I'll check out Megascan, which I know about, but never used.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            You do get some awkward people don't you?!
            Anyway it's unreasonable of them to expect an exact representation of the rocks, so I would suggest modelling their general appearance and applying the best suitable textures that you can find. That should be sufficient as it's mainly their size/shape/colouring that is important.
            Get them to provide many many angles to assess their shape - at very high resolution may even give you useable texture info.
              If you wanted to try doing something new for the sake of self learning, you could try to photoscan the rocks on your cameraphone so you've got a shape guide and then fill in that silhouette / volume with scanned rocks. Meshroom is a free photo to model program that should do it!
                Yeah, however, 99% of my clients are 100's and 1000's of miles away. Over the past 5 years, I have done 2 projects for local architects. I might ask them to give it a try.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  I looked over Megascan, but I don't think anything will work. I had a job like this many years ago, probably 8 years ago at the time, I didn't even know about the script Drop, so I hand placed hundreds of boulders. I think I am simply going to use Forest Pro with a hand full of boulders.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Here is an early proof. I am waiting for a landscape plan, which should liven things up. The rocks took me about 5 minutes using FP. They need work, but I think it'll work.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Oh, I thought it was just the ones circled - but anyway this'll look great with a bit of variation. Very cool that they incorporated it.
                        Yeah, I'll have to change up the color variation, but that'll be easy. I have some early site photos and I assumed that it was construction debris, so I can't say that they dropped it on my after I quoted. I guess I shouldn't assume .
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Well to be honest that is what I thought initially - lazy excavators
                            Still struggling getting grass right, so have to ask again, is that the photoshop trick or FP grass?
                            • #15
                              Both. My render times are only about an hour for my exteriors, so I use FP grass to get edges and then PS to make it look real. The image I posted above is all FP.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
